Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
It boots, chimes, keyboard, fans, responding,
Hi,
My favourite Macbook Pro 17-inch A1297 2011 model is powering on, with black screen. I tried resetting (CTRL,Shift,ALT,Power & CMD,ALT,P,R) many times, but nothing changed. I can hear Apple Logo chime, I can hear HDD working, as it is loading OS (High Sierra) , I can see keyboard backlight turning on/off depending of external lightning, but screen is totally black, no backlight at all (tried with a torch just in case). I connected external monitor (with tested adapter), but even after loading OSX nothing also to external display. No water damage at all, I am the only user. Also have checked LVD connector, everything seems fine.
I know graphics issues for this model, board had replaced free from Apple repair center a few years ago (replacement due to graphics issue). I never had graphics problem, and was keeping always coolers clean. Any help could be highly appreciated.
Add a comment
1 Answer
Looks like there could possibly be a short in the LVDS:
https://youtu.be/KjIQXwitWCI
Try it and see if it works and update if it does.
Try to disconnect the LVDS connector and see I it boots to external monitor first.
Good luck
2 Comments:
Yeah, I have seen that video, but unfortunately not. Same with LVD disconnected, it chimes, boots, you can hear HDD working, keyboard backlight turning on when it loads OSX, but nothing on screen. Could it be a bad graphics card? Usually there are distorted screens, strange colours, and not able to boot if so, but totally black, and everything seems working ? I can hear HDD spinning after a few minutes, when I am entering my user password …
by
Shorted IC components along the graphics line can also do this. I think you'll have to look up some Louis Rossmann videos because one of this solutions could help you. Of course, if you aren't able to do IC board repair, it's most likely something he could fix and you'd have to send it in to him.
by
Add a comment
Add your answer
Vassilis Giannakopoulos will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 4
All Time: 67
