Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
873 Questions View all
I changed my front facing camera and speaker but can only take calls
I changed my front facing camera after damaging the cable whilst changing the battery. I can only take phone calls now on loudspeaker. I’ve changed the speaker but still the same
Add a comment
Check the ffc connector for damage and reseat. Where did you get your parts from?
1 Comment:
OPTIONS
Off eBay. It seems that it’s seated ok would that cause the problem with the speaker not working but only the loudspeaker
by
Add a comment
Add a comment
Oh Man! You messed up with your front earpiece flex cable. The flex cable should connect to the board which is responsible to get power to earpiece.
1 Comment:
Sorted, it wasn’t quite lined up
by
Add a comment
Add your answer
gerard morgan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 52
