Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
Forgot to split Fusion Drive
Recently I replaced the 1 TB hard drive with a 1 TB SSD and forgot to split the fusion drive. Since I already paired the old SSD to the new SSD I cant simply reconnect the old drive. I plugged the old hard drive into another computer i have and the drive wont mount. Is there anyway to get the data off the hard drive?
Add a comment
1 Answer
Chosen Solution
First setting up a dual SSD Fusion Drive really doesn’t improve performance! Depending on the size of the blade SSD its best to just setup a dual drive config with the blade SSD setup as the OS and App drive. If you have a small Fusion Drive SSD (128 GB or smaller) then its best just to leave it unused.
As far as recovering your files from the original HDD if you’ve installed anything higher than High Sierra (likely here) then your drive is setup with APFS file system so older HFS+ drive & file recovery tools are useless! Apple has not offered the drive/file recovery folks the means to recover drives or files under APFS.
As you’ve over written the cache drive (blade SSD) the keys are gone!
Score 1
2 Comments:
So basically I would need to pay for a data recovery if I want to get stuff off the old drive?
by
I don't think they can do it either ;-{
by
Add a comment
Add your answer
Naitsa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 283
