A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 Questions View all
Cant change the hdmi port.
I'm using an Ayoue 2703 A+ repairing system set to 480 c and 100 P to attempt to do hdmi port repairs on a ps4, and xbox 1 s. After about 20 minutes or so I was able to get the old ports off, and with flux applied after 20+ minutes the solder is not revolting for me to apply the new hdmi port, is there some trick I'm missing here?
1 Comment:
any updates on your repairs?
by
Add a comment
1 Answer
Make sure you are using a quality solder and flux. Also, ensure your air is high enough to move the heat properly. You should be using leaded solder to do this repair. Make sure to use solder braid to remove all original solder. When in doubt, use more flux. Just make sure to clean it off after.
Add a comment
Add your answer
Scott K1ll3r will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 62
