Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
AMD GPU Failing problem
Having issue with failing AMD GPU. I have tried reflowing to no avail as well as removing relevant kext.
Does anyone have any software/drivers that they have used to bypass the AMD GPU? Thanks in advance
Add a comment
1 Answer
I gave up trying to save them ;-{
The best solution is getting to a better GPU! Luckliy you have an out. Apple carried the 2011 design to the 2012 model. All you need to do is get a new logic board:
  • 661-6491 - Logic Board 2.3 GHz i7
  • 661-6492 - Logic Board 2.6 GHz i7
They are running around $500 USD recycled.
The only thing you need to do is a slight modification to the 2011 displays LVDS cable using a nail file as described here:
Add a comment
Add your answer
Liam Boyle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 85
