Fan running constantly after display replacement
Hi. I replaced the display on my MacBook Air last night using Ifixit’s kit. All went well. The new display works great, and everything else is functioning normally. However, the fan runs constantly even without intense usage. The computer is not even hot either. I’m worried I may have done something wrong during the replacement. Any ideas on how I can identify the exact problem? Thanks.
UPDATE 5/15/20
I adjusted the fan settings in TG Pro to “Auto Boost”. This overrides the OS control of the fan, and sets the fan speed based on the temperature of the computer. I attached a screenshot below. As you can see, everything looks good. However, it says the fan is at 0 RPM, but it is still running full blast! Any help would be appreciated. Thanks.
Does your iSight camera work?
by Dan
@danj Yes, it does
by Juan Rodriguez
Juan - I was hoping it was a simple problem.
OK, time to pull out the big guns!
Install this app: TG Pro you'll want the full version to get the diagnostics. Post a snapshot of the apps main window (you'll need to resize it so all of the sensors and fans are visible and post it here for us to see (as well as the diagnostics window too) Adding images to an existing question
by Dan
Thanks @danj. I finally installed the app and added the image above. Let me know your thoughts.
by Juan Rodriguez
