The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
150 Questions View all
Ipad 6th wifi not charging problem
I have ipad 6th gen it’s not charging and i know there is 2 possibility Charging port and tristar ic. But i have already measure the voltage on charging port to the board and it says 4.97 volt (nearly 5 volt) is that normal??? Or another problem is tristar ic so, my question is. Is that normal 4.97 volt on ipad charging port? Thanks
Add a comment
1 Answer
Most Helpful Answer
What are you using to measure the voltage? A multimeter or a USB amp meter that you plug into the charger? Tristar is a USB validator, not a charging IC. It basically acts like a bouncer at a night club to make sure that the “ID” of whatever is plugged in is safe to use. If the device is powered on and won’t receive a charge, I don’t believe it’s related to TriStar.
Score 1
Add a comment
Add your answer
Satriya Handha will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 371
