Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Questions View all
What is the best way to clean the logic board on a MBP early 2011?
I don’t have the technical skills for starters. However I recently replaced the hardrive cable following the Ifixit detailed instructions and it worked. While i have it opened I noticed loads of dust on the logic board but not sure how to clean it without damaging it.. Thank you in advance
Score 1
Add a comment
1 Answer
Chosen Solution
I use a small soft paint brush and a can of can’ed air. carefully brush the surfaces to loosen the stuck dust, use the can of can’ed air to push the debris away.
Score 2
5 Comments:
Thank you for your prompt response. One further question, does any can air can be used used? I read something about that some might provide static electricity. Thanks again
by
@gustgo Canned air can be used. Just don't use a vacuum because that will cause static electricity to become a problem.
by
Thanks a million
by
Can'ed Air won't, Vacuums do!
by
@danj thank you, greatly appreciate the advice
by
Add a comment
Add your answer
Gustavo Gomez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 54
