Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
Question Closed
MacBook Pro mid 2010 sometimes take charge and somtimes not
Hi!
I have a macbook pro (mid 2010) that has a strange problem. Everything works well except the charging part. Often when i plugg in my charger, nothing happens. The macbook won't recognise that the charger is in fact attached and the green/orange light on the connector won't light up. If i unplugg the charger and wait a little while and then replugg the charger, it works and the macbook is charging normally
I bought the macbook from a friend that told me that he believes it is a fault on the logicboard. Can this be the problem? Is it possible that something is wrong with the DC-in board?
So to clarify, the macbook sometimes recognise the charger and sometimes it won't. Everything else works like a charm and the computer runs perfectly on battery.
Best regards
Olof from Sweden
Add a comment
1 Answer
Most Helpful Answer
Go here, enter your serial number and check to see if you're still under warranty: https://selfsolve.apple.com/agreementWar...
Score 2
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,782
