The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
Data Recovery File Permission
I have an early 2014 MacBook Air that will no longer boot. I got an OWC Envoy case and removed the ssd to try and recover the data but when I connect it to our iMac, I keep getting a message when I try to open files I keep getting the following message “The folder “Desktop” can’t be opened because you don’t have permission to see its contents”.
Is there a way to change the permissions on the files?
Add a comment
1 Answer
Most Helpful Answer
Yes!
Right click on the drive from your desktop goto Get Info and then at the bottom twist the twisty on Sharing & Permissions: Then unlock the padlock so you can make the changes. You’ll need to use the User Name & Password of the other system (admin). Once you’ve gotten access you can then add your account info using the +
Score 1
2 Comments:
This worked! Thanks Dan!
by
Your welcome! Don't forget to accept the answer!
by
Add a comment
Add your answer
luke7203 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 80
