Repair guides and support for a wide range of small engines.
103 Questions View all
Why is my mower backfiring?
I have a zero turn Husqvarna that will start up and run great. No problem riding around, but whenever I engage the blades and start to cut, the engine backfires. I will also say that this happens in places where the grass is high
Add a comment
1 Answer
A spark plug that is damaged, worn, or has an improperly set gap between its electrodes creates a weak spark. As a result, the fuel may not ignite in the cylinder, but it might ignite when it reaches the hot exhaust muffler. The result is a loud backfire. Poor spark also results in a mower that runs unreliably.
1 Comment:
But why does this only happen whenever the blades are engaged and cutting
by
Add a comment
Add your answer
Tyler will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 35
Past 30 Days: 141
All Time: 1,411
