Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
Vacuum won't let me push or pull on carpet.
I was using my Navigator Lift-Away Pro on the carpet and it was working fine then the red light came on and I couldn’t move it. After cleaning I tried it again soon as I put it back on the carpet it did the same thing again it seems the brush stops spinning.
Add a comment
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
Add a comment
Because of such a malfunction, I damaged my carpet.
Add a comment
The red light indicates the brush roller has stopped. Something is caught inside the roller brush. Turn off the vacuum. Remove the object and turn it back on. Green light should turn on. Remember, brush roller needs to be turned on when your vacuuming carpet. If not it will be hard to push.
Add a comment
Add your answer
drosser333 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 108
All Time: 6,659
