The larger edition of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
107 Questions View all
Is Galaxy s10 plus replacement screen waterproof?
Or should I buy silicone around the corners ?
I’ve seen some people changing the whole front screen, taking out the battery and placing into the new screen. So the new screen should have adhesive inside already?
Add a comment
Chosen Solution
No phone is 100% waterproof to begin with. If you want to change the screen and frame buy a samsung service pack as it will be the same as factory.
Score 2
2 Comments:
What happens if you do not use adhesive to stick the screen back on?
by
It won’t stick
by
Add a comment
Samsumg S10 display replacement water proof yes ya
1 Comment:
No it’s not waterproof
by
Add a comment
You can buy a replacement screen aftermarket, get it with the frame. It will be waterproof if you reseal the back cover. But that depends on how good your work is. You. Have to take the back cover off to take the phone apart to replace the screen. So it all depends on who puts it back together and if they seal it correctly.
Add a comment
Add your answer
Abbe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 12
All Time: 3,963
