Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
212 Questions View all
What is the highest speed, proccesor that can be installed?
So I have a late 2012 iMac that I got for free from my school, I want to put a 1 TB SSD in it as well as 32gb if that’s possible, and I want to know what processor I can put in it to give it the best specs possible.
1 Comment
Here's a listing of your models series: iMac13,1
by
Add a comment
1 Answer
Most Helpful Answer
The best CPU you can install in this series is a 3.1 GHz Core i7 (I7-3770S)
As far as RAM its limited to 16 GB.
Depending on what drive option the system came with you may not be able to add a second drive. The SATA HDD models don’t have the ability to add in the PCIe/NVMe blade SSD drive, If you got a Fusion Drive system you already have two drives present (you’ll need to break the set before you can remove either) and the blade only model can have a SATA drive added with adding the needed HD SATA cable.
Score 1
Add a comment
Add your answer
David bellows will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 5
All Time: 42
