Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
When I am calling, the person is not able to hear me?
When ever i call someone from my iphone than i am able to here their voice perfectly but they are not able to hear me and also my center key is not working, what should i do??
Add a comment
Chosen Solution
the problems all originate from the dock connector...the contacts for your home button, and the mic for when you are talking. to test the mic open "voice memo" app and try talking..you should see the needle moving. you can then press play and should be able to hear it back. if it doesn't work then replacing the dock connector should sort the problem out.iPhone 3G Dock Connector Replacement
Score 3
Add a comment
The fix is to carefully reconnect Flex Cable #4 to the Logic Board.
Score 1
Add a comment
you have options:
fisically
maybe the cristals are broken
maybe you need to move the speaker
or the speaker are disconnect
or the speaker cable is damage
by softs:
restore the firmware to deafult
flash the phone (in iphone's phone this not work...)
update to the last firmware
you can find the instructions for disasembly, or the diagram for to find the damage.
NOTE: my english its a little bad... I am from of Ecuador
Add a comment
Add your answer
Mehfuja will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 494
