iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Questions View all
iMac Intel 27 End 2009 Upgrade the drive to SSD?
Is it a good idea to upgrade the drive to a SSD?
because it is near 2 years old ...
if so, what do i need to make it on my own?
do you have this parts? what SSD would you prefer?
thank you from vienna,
robert
2 Comments
i have 8 GB of memory ...
by
This question was migrated from http://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Chosen Solution
Yes, but it will run at SATA II speeds. When it comes to the 2.5->3.5" adapter, these are common and easy to find. You can find these from places like Newegg and Amazon.
When you attach the temperature sensor, it needs to be attached to the SSD; not the 2.5->3.5" adapter. Your iMac uses a digital temperature sensor, so you will need to match the drive brand or use a 3rd party sensor like the one sold by OWC.
When you replace the drive, the guide can be found here: iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement
Score 3
Add a comment
Add your answer
Robert Farthofer will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,360
