Released in 1999, the Braun Exact Power EP100 is an electric beard and mustache trimmer. It has an internal rechargeable battery.
3 Questions View all
hair trimmer cut hair very short period, WANT TO CHANGE BATTERY
Type and capacity of battery to braun ep100
What volt
What watt
What mah
update
Great thanks for all who help me
update
Please if possible
Answer on one more question
Very important!!!
What capacity of battery must be in broun ep 100, there is 1 battery, but
What capacity?
500 mah or 1000 mha
Very important
Great thanks
Score 2
3 Comments
One of the clearest and most direct questions I've seen asked on Answers in my time here.
by
The higher the maH the longer it will last on a single charge.
by
the person who wrote the how to guide also said he used a higher mAh battery and his charger didn't last so long. something worth considering
by
Add a comment
Chosen Solution
http://forum.eserviceinfo.com/viewtopic.... I found this link to how to get to the battery (page 2)but couldn't find what exact battery was in your trimmer. You will be able to find that by taking the trimmer apart and then matching it up after. good luck
Score 7
2 Comments:
+ for finding out how to change it
by
Yes indeed--I looked for some time with no luck. +
by
Add a comment
That wasn't easy to find but you need - (3 AA-size, 1.5V)
http://www.braun.com/global/male-groomin...
I'd also get a battery charger and rechargeable batteries like this one: http://www.google.com/products/catalog?c...
Score 5
3 Comments:
Good research on your part also. +
by
Only the EP 15 and Allstyle use the 3 AA size batteries. the Battery on the EP 100 is soldered to the logic board
by
Very good OT, I missed that.
by
Add a comment
Well here is a replacement R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm Fits Braun Models: Action Line, EP50, EP60, EP80, EP100, 540, 570 from here http://www.electricshaverstore.com/get_i... and here is the service documentation. The EP100 actually is a Braun 5601
Score 3
3 Comments:
+ nice searching
by
+ You have a plethora of resources.
by
;-) Could not fix some of my old "stuff" without those resources. I actually purchase and repair according to the manuals I can get, makes my hobby easier.
by
Add a comment
Add your answer
IGOR will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 29
All Time: 6,375
