Model A1213 / 8, 16, or 32 GB capacity
216 Questions View all
Question Closed
iPod Touch is Disabled - Tried everything
I've gone through this site and I don't see anything that will help me with this issue.
My son in his brilliance added a passcode to my ipod and then forgot it. By trying over and over again to enter the passcode he got locked out.
Normally this wouldn't be a problem, but to add to my misery I got the blue screen of death on my computer and had to reformat the hard drive. I had to redownload iTunes.
When I try to put it in DFU mode, while I am holding the home button the apple logo appears as soon as I touch the on/off button. I've tried this 20 times, same result.
iTunes gives me this message...
iTunes could not connect to ipod Jodi because it's locked with a passcode. You must enter your passcode on the ipod before you can use iTunes...
iPod is disabled so I can't enter the passcode..
I would appreciate any help you can give me..
Thank you in advance
Jodi
2 Comments:
I finally got it to go to recovery mode
by
I held down the on/off button and home buttons the Apple Logo popped up right away, but I held the home button for approximately 10 seconds and it went into recovery mode. I think you have to cancel the other msg (iTunes could not connect to ipod Jodi because it's locked with a passcode. You must enter your passcode on the ipod before you can use iTunes...)before it will work.
I hope this helps someone else..
by
Add a comment
1 Answer
try redsn0w or something to skip the itunes errors
make sure you download right version to flash thou
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,064
