Repair guides for the MacBook.
3787 Questions View all
Why is my sleep/wake screen has this light only in the center?
Sometimes when you open a macbook it has this dark screen where it happens when you press the button to make it deem the most. But then, even if, I didn't deemed my screen sometimes when you open your macbook it's selected to the deemest screen and can not make it brighter. And so, I use to just close and open again and then it works fine.
However, I just got this another problem, where first, when I close my laptop it makes this CD ROM turning sound constantly, then now, when the mac is in the deemest mode, only center is bright enough to see but the other sides are totally turned off or too dark to see anything. I just want to know what's going on with my macbook.
Add a comment
1 Answer
Chosen Solution
Please hook your machine up to an external monitor and let us know if the external is exhibiting the same symptoms as the MacBook scree. It also helps us to know which machine you have. Please give us the last three figures of your serial number (located in the battery compartment of most machines).
Score 2
1 Comment:
Unfortunately, I can not connect to an external monitor. But it seems like it has those white spot, even if, the computer is turned off... I tried to find answer for this, but I think this is a unique problem. Is there a way to upload pictures?
by
Add a comment
Add your answer
Peter will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 502
