A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
239 Questions View all
What to do when I accidently got water over my MacBook Pro?
Hi!
I just accidently pored water over my computer. I shut it down and removed the cable. Now it layes open and up-side-down. What would you suggest is my next step? Please help! Thank you
Add a comment
Chosen Solution
While this guide is for a different model it outlines the risks of leaving your system wet internally MacBook water damage diagnostic
Basically its a matter of disconnecting your power so you don’t engage electrolysis ASAP! Then you need to get the water out as soon as possible! That will require opening your system quite extensively. This assumes you have the needed tools and supplies. It might be better locating someone local to you who can help you.
Score 1
2 Comments:
Thank you!
I do have the tools, and I read that I need to turn of the auto-boot in the terminal, so my next question is if it is ok to start the computer and do that? Or just open the computer?
really appreciate your help, thank you
kind regards, Pia
by
Your system is a bit different than the older systems which really had the system fully off when you shut the system down. Your system has one eye still open! So its still draining power even if its off this the issue you need to run the terminal command to fully shut the system off. Disconnecting the battery before you do this can corrupt your systems storage. It depends on what you had open when you turned the system off or if its just in sleep.
So yes you need to run the command if you can, if you can't then you have no choice! Disconnect the battery.
by
Add a comment
MacBook water damage is not easy to repair; even minor spills can present advanced issues requiring lots of tools and expertise. ... Beware of any advice telling you to simply allow it to dry or clean it with alcohol; modern MacBooks have many components that can be damaged by a spill.
  1. Immediate unplug your device. ...
  2. Power down the laptop. ...
  3. With the screen still open, flip the laptop upside down. ...
  4. Remove the battery. ...
  5. With the computer upside down, gently dab the area with a paper towel.
upsers account
Add a comment
Add your answer
Piafra will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 91
