Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Questions View all
Can’t download the additional components
Was trying to sell old MacBook Pro 2011, followed a video to reset using command r upon restart all worked fine till got this message after trying to re install Mac OS X Lion , “ can’t download the additional components needed to install max OS X”
1 Comment
Did you solve this? I have the same issue
by
Add a comment
Most Helpful Answer
Try using internet recovery (Command + Option + R) instead.
Score 1
1 Comment:
we have MacBook Pro from 2015 and it was failing exactly in the same way. On Apple web was to press "Command + R" and i had followed the Guide, but when i tried your advice "Command + Option + R" there was brand new version of the guide and it worked.
So people : try (Command + Option + R) instead.
by
Add a comment
Seems there’s an answer here: re installing OSX problems. May be linked to outdated certificates, and the only way I think you can solve this is by creating a new installer on to a USB key, or by (somehow) setting your clock back before you install. I couldn’t figure out the clock option since I already formatted the system, so I am trying the USB route.
Score 1
1 Comment:
The clock can be set from an external bootable drive (making sure you aren't connecting to the Internet's time server - Unplug your Ethernet or WiFi connection) when using the USB bootable installer. Or using the a terminal session Changing system date from Terminal – OS X recovery
Trying to access the Apple servers over the internet to do the internet recovery will cause your system to access the time server (resetting the date to the correct date) so you can't get the OS installed.
by
Add a comment
While solving the same problem, I solved it with the solution methods given on the page. maybe it will help you
https://www.knowerstech.com/cannot-downl...
Score -1
Add a comment
Add your answer
mando hernandez will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 52
All Time: 8,072
