Model A1138 / 1440x960 screen resolution
85 Questions View all
How can I repair or replace the bottom case lock latch?
The lip on the bottom case lock onto which the hook from the top case latches is broken. It looks like it can't be repaired, but I'm not sure. Perhaps the whole bottom lock case needs to be replaced, if a used part can be found.
Thanks.
3 Comments
Thanks for your help,TommyJames.
I think I have found the part (just the bottom latch box). Now I need help taking the old broken one off and putting the functional one in. Are there any instructions on this procedure?
by
A picture would really help us help you. Lower left hand corner of this window.
by
Thank you, meyer. I have uploaded a picture of the damaged bottom latch, which I'm not sure how to replace with a functional one, even if I manage to find a used spare part.
by
Add a comment
1 Answer
Chosen Solution
Yup! The whole bottom case will unfortunately have to be replaced if the damage is bad enough. Just search eBay for the parts. :)
Add a comment
Add your answer
Dusan Lazarevic will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 959
