Support for the third generation of Chrysler Town & Country spanning model years 1996-2000.
11 Questions View all
Water leak in straight stream out of the timing cover
My van has a straight stream of coolant squirting out between the timng cover and motor how do I fix this thanks in advance
2 Comments
Hi,
What is the model year and engine size?
by
Model is a 2000 it has a 3.8 engine thanks
by
Add a comment
Chosen Solution
Replace the timing cover gasket.
UPDATE 3/5/20
Here’s how to do it:
https://www.autozone.com/repairguides/Ch...
Score 2
1 Comment:
I kinda knew that but how to do it I don't
by
Add a comment
Hi,
Check that the water pump is not leaking coolant.
Here’s a link to the service repair manual for your series vehicle.
Scroll down and click on the Cooling System link , pass the reCAPTCHA test and when the pdf file opens go to p.7-19 to find the procedure to inspect / replace the water pump for a 3.8L engine.
Score 1
Add a comment
Add your answer
Daniel Billings will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 129
