Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Red screen Boot loop
I have a iPhone 5s with boot looping and appears a red screen. I know that can be a lot of problems, but I don’t know how can I test and find the problem. I have a multimeter and a soldering station. I already have removed the motherboard. And now, I d’like to test with the multimeter if is some problem in the tracks of the front-facing camera. And if not, how can I test the Tristar or the worst case the NAND.
Score 1
Add a comment
1 Answer
Chosen Solution
You should rule out a parts issue before moving on to the logic board. You haven’t told us what diagnostics you did before removing the board like.
·         Disconnected front flex assembly
·         Disconnected home button.
·         Replaced screen.
·         Replaced battery.
·         Tried a hard reset.
·         Tried an update
·         Restored the phone.
Once you know it isn’t a parts problem you can move onto the board. You could test Tristar with a Tristar tester or you can diode the dock connector and compare readings to a known good board.
 As for the NAND I would see if any errors came up in iTunes while doing an update or restore.
Score 2
3 Comments:
Thanks for answered, @imicrosoldering. At first, I have replaced the battery. And after, the screen. Also, the home button wasn't working and I replaced for a new.
Update: I already disconnected the front flex assembly, because I also got a problem with this, the same problem. For this reason, I suppose that the problem could be the tracks of the motherboard.
by
After a long time, I decided to try to give one more chance to repair this iphone 5S. Until the last update of this post, I had not yet done the tristar test with the card in the connector because I had to travel and I was without any of the equipment. Only today was I able to take the test. The pins have stable values, pin 4 is the only one that has no signal on the multimeter. So, as I read, I believe it probably must be the charge or battery, right?
by
@thatoo_apple Put it in recovery mode and try an update or restore with iTunes.
by
Add a comment
Add your answer
thalisson_santos will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 18
All Time: 408
