Repair guides for Android cell phones manufactured by Sony Mobile and Sony Ericsson.
screen not working/can't answer calls
Hi,
I have one of these phones and to look at it you would think it is in perfect working order, only the screen doesn't
work, The screen isn't cracked at all, I just cannot answer a call or unlock it ? Any ideas as to what may be wrong with it? Many thanks :)
Score 1
1 Comment
My Phone is the x8 :)
by
Add a comment
1 Answer
Chosen Solution
I attached an image of the Touch Screen test procedure. You might want to start there. If it shows that you have problems with your digitizer, the manual recommends that you " Check:
Inspect the touch screen of the Cover Front assy.
Action:
1. If dirty – clean it
2. If the touch screen is damaged – replace the Cover Front assy.
Check:
Inspect the ZIF connector of the Cover Front assy to the Main PBA.
Action:
1. If not properly connected – disconnect and reconnect
2. If dirty or oxidized – clean the ZIF connector.
Check:
Inspect the flex film for the touch screen on the Cover Front assy.
Action:
1. If the flex film for the touch screen is damaged – replace the Cover Front assy.
Now if it is malfunctioning, you can/should replace the digitizer to remedy that. The original part number for the Cover Front assy White is 1239-3969. It is available at places like this. Now if you need the parts manual as well as the service manual with embedded videos about your X8 it is available for your download right here. :-) Good Luck
Score 1
Add a comment
Add your answer
Tracey will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 687
