iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
Help with Testing iPod Classic logic board with a multimeter
Guys I have a pristine ipod 80gb . It doesn't power on .
So far tested
Display works finne
Harddrive is fine
New Battery
Clickwheel is fine
Tried connecting to the wall charger without battery
I'm really tired need help solving this .
How do I test the board with a multimeter to check if it's shorted out or not
Add a comment
1 Answer
Most Helpful Answer
@johnwick90 extremely difficult to do since there are no schematics for the iPod. You can check the 30 pin dock connector wiring and see if that is working properly. Check the battery connector on the board since that is a weak spot on those boards. Make sure it is connected properly etc.
Score 2
2 Comments:
Thanks for replying I had seen your old post I had checked the fuse
The power management IC
USB port
Battery connector
All of them are fine. I just don't know what's wrong with the board
by
Check the coils around the power management IC's and battery connector
by
Add a comment
Add your answer
John will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 546
