Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Home button and touch ID not working after battery replacement
Not sure what my next course of action should be. I checked all the cables, everything seems okay. I was extra careful and didn’t bend the screen past 90 degrees. when opening it. 3D touch still works so I don’t know. The home button doesn’t do anything when pressed and it says Touch ID cannot be enabled on this iPhone. Literally every other function of the phone works perfectly. Never had this issue before. Should I order a replacement screen and try that? Maybe I damaged the flex digitizer cable?
Add a comment
1 Answer
Most Helpful Answer
Check the vertical cable connector at the top right of the board where the screen and everything connect. Make sure there aren’t any bent pins or damage to the cable.
Score 1
1 Comment:
I don't see any bent pins whatsoever. I'm completely perplexed. Ordered an OEM screen replacement so maybe I'll try that.
by
Add a comment
Add your answer
Brian Keegan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 115
