Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
Replacment V-Sync cable for 2011 21.5” iMac, where can I find and buy?
Hi all.
I have a 2011 21.5” iMac answer it’s all set up and ready to go, except when fixing it I broke the v-Sync cable, I’ve been having trouble finding any for sale. So I’d love some help from the community to see if they know where I can buy some from?
Cheers
Add a comment
Chosen Solution
@quinn218 do an online search for apple part number 922-9799 or Apple manufacturing number 593-1389-A  which is the Cable V-Sync/LCD Temp Sensor for an iMac 21.5inch Mid 2011. Readily available and not overly expensive.
Score 2
3 Comments:
@oldturkey03 - Good catch! I haven't needed to find one as I'd always had a junker or two to steal the part from.
Here's a source I found https://www.ebay.com/itm/Intel-iMac-21-5...
by
@danj @oldturkey03 So just to clarify, the V-sync cable also goes under the name "LCD Temp Sensor"? Thanks for your time.
by
@quinn218 it's a combination cable
by
Add a comment
Finding discreet display parts is always tough.
You’ll need to talk with one of the larger parts houses which recycle used systems. As an example in the UK TheBookYard I find them very helpful for odd requests. It may take a bit of time as they would need to strip down a bad display they get in for the part.
Otherwise you’ll need to replace the entire display assembly.
Score 1
Add a comment
Add your answer
Quinn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 174
