Replacing right hinges and iSight and Airport/Bluetooth cables
Hi all,
MacBook Pro took a tragic fall! Clutch cover popped off, busted the threading in the hinge screws,
Cables fraying by the second. I made a futile, messy attempt at tightening the screws that hold the hinge to the display assembly with some Threadlocker adhesive and cannot find any info about the ones necessary for replacement anywhere. Are they T6? T8? One of them definitely looks smaller than the other.
Thanks to a lot of helpful answers on this forum, I figure that I need to replace the hinge with a new one that has the appropriate antenna cables so I can feed wires through the hinge again.
Do I just need to replace the screws in the hinge in order to re-attach the display? What screws are they?
Thank you for any info you can provide.
