Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Second internal drive not initialised
Hi there!
Been runing my Macbook Pro 13’ mid 2012 for a while with a Samsung 840 EVO SSD and a Toshiba HDD as replacement for the optical drive.
Now I changed the optical one for a Samsung 860 QVO and it just says drive not initialised…as external drive it works just fine so whats the problem?
Disk utility doesn’t really do anything.
Is it possible I can’t run this SSD as optical replacement or what’s the deal?
Attached a couple of screenshots:
Thanks in advance!
Phil
Add a comment
Chosen Solution
it’s an electronic issue…the cable that runs on the logical casing caused an error…
Just put some tape underneath it and problem solved!!!!
happy days!
Score 1
Add a comment
The cable also gets damaged on the top ledge. I use 3M extreme mounting tape to protect it.
Score 1
Add a comment
Some Macbook Pro’s have an issue with the Optical drive SATA port. While the 2012 models had been fixed I wonder if the newer Samsung drives interface driver has a problem. You may need to update it. The 870 EVO Plus had a driver issue which Samsung has fixed.
Let’s try this take your current 840 EVO out of the HD bay and put your new 860 QVO in its place. Are you able to install macOS onto it via Internet recovery?
If that works that is pointing to an issue with the Optical drive SATA port.
In anywise do make sure you have the newer HD SATA cable as its known to have issues! Place some electricians tape on the uppercase where it crosses over and don’t crease the cable! Instead create an arc using a BIC pen ink straw (or similar ink straw, empty) to help form the radius.
I haven’t encountered issues with the Optical drive’s SATA cable but you might want to give that a try as well if the HD bay works.
1 Comment:
thanks mate but a bit of tape fixed the whole thing...do you reckon it'll be better to put the new one (860 QVO) into the HD bay?
One SSD is meant to hold my tunes ( about 800gb) and the other one to run the system and hold apps, pics etc.
Currently I'm restoring my itunes library from icloud and the macbook is steaming...
by
Add a comment
Add your answer
youthed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 109
