All-in-one desktop computers from Apple. iMacs were equipped with Intel processors from 2006-2021.
7458 Questions View all
Can't eject dvd tried all ways of ejecting, none work
imac won't eject dvd have tried all methods, holding mouse down whilst restarting etc. have been told i have to take out screen and remove dvd with pliers.
Has anyone done this? how do you remove screen?
Score 1
Add a comment
Chosen Solution
here is a link to a previous question about this problem with several answers. In particular scan down to macheads solution. Good luck.
http://www.ifixit.com/Discuss/thread/653...
Score 2
4 Comments:
thanks for the info will check it out now.
by
hi rj713 the advice is for macbook pro, after reading though I think I could fix it in my imac if I knew how to get into it.
by
The original post was for a macbook pro but macheads advice is for any optical drive.
by
Thanks for the advice
by
Add a comment
Go to Applications--Utilities Launch Terminal.app type drutil eject then press return
Score 2
5 Comments:
Hi mayer, have tried that. Thanks for response.
by
Of course when someone says "I've tried everything", your everything may be very different than a techs everything. When you hit the eject button on your keyboard are you getting any sounds? Is it a full sized disk in the machine? What are the last three figures of your serial number?
by
the last part of the serial no x85,yes it is a full size disc, when I hit the eject it makes the sound it usually makes, sounds like it's coming out, then the comp moves into front row
by
That serial didn't work. Look on the bottom of the stand.
by
model no A1224
Serial no ends X85
Ethernet ID ends FCF
by
Add a comment
you dont have to use pliers theres a tiny hole that releases it on the side use a needle and it will be free when powered down a thin piece of plastic and some two sided tape slide it out popsicle stick too thick give it a try theres some real thin two sided tape staples on sale spring might have got loose or you might have jamed two disk in on accident or lever over shot its stop point and now in limbo so use a disk on a stick should here the lever go back in place when done
Score 1
1 Comment:
cheers cuttingedge9 just tried your last suggestion, sadly it didn't work.. when or if I get into my mac I will try your first suggestion.
by
Add a comment
Add your answer
will jennings will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,268
