Released by Samsung in March 2016. Model SM-G930.
425 Questions View all
My phone only charges off laptop
My Galaxy S7 is almost brand new. I got it, and when I was doing some work I accidentally got a thorn bush seed in the charging port. Managed to dig it out but now it only charges off my laptop and wireless charger. It says there is a problem with the battery when connecting it to any fast charge cable, and it won’t do anything at all off normal USB. Data transfer also doesn’t work, the file simply gets corrupted when transferring it from the phone to a computer and vice versa. Any USB that fits tightly in the port won’t work, and any one that is loose is very finicky.
Add a comment
1 Answer
Most Helpful Answer
Sounds like some pins might’ve been bent when the seed was removed from your charging port. If some data pins are touching each other, this can cause the issues you have described.
Unfortunately the charging port replacement process for this phone is nearly impossible without factoring in a screen replacement as well. I recommend using wireless charging for this device to prevent further damage to the charging port.
Score 2
3 Comments:
Well it can be done by an experienced microsoldering technician. We use hot air to remove the old port and solder a new one on. There are videos on YouTube that show it can be done.
by
@benjamen50 is this what you're referring to?
https://youtu.be/nzYmecOucgU
I've never seen it done for a Galaxy S7 but I suppose it's possible. Thanks for the info!
by
Yep that's how I do it. I do it for the S6 to s7 edge and note 5 too.
by
Add a comment
Add your answer
Shadow soul60 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 828
