2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
MacBook Pro won't power on most of the time
Hi,
My mid-2012 15” Retina MacBook Pro won’t start most of the time. After pressing the power button, the fans ramp up to full RPM, however the display remains black and I can hear no chime. From my research, this usually means that the mainboard is dead.
However, the biggest difference that I have from the other cases I have seen online is that from time to time, the MacBook does actually start, and when it does so it works perfectly, until it is shut down and the issue happens again. I have obviously tried resetting the PRAM and SMC with no luck.
Does anyone have any experience with a similar issue? The only thing I can think of is to try reflowing the mainboard, however if anyone has any other ideas I would really appreciate their help.
Thanks in advance.
1 Comment
I would check both the cord MagSafe connector and the DC-In Board pins are they in good shape or carbonized? You might want to also check the battery health using CoconutBattery Post a snapshot of the main window for us to see as well Adding images to an existing question a battery which is worn out can react this way.
by
Add a comment
1 Answer
Chosen Solution
Well, maybe not “dead” but it sounds like the logic board is in great need of a repair. Hard to tell what maybe wrong without testing, the problem you report doesn’t make any bell ringing for a specific typical board issue. It maybe some capacitor or resistor going bad, but this on and off behavior doesn’t offer much to speculate on. Unless you’re ready to replace the board the alternative would be to find someone in Macs component level repair and cross fingers. I don’t see how a blindfolded reflow might help..it would rather increase the risk you will have to trash it.
Score 2
Add a comment
Add your answer
Daniel Gauci will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 76
