SSD incompatible with iMac Retina?
I recently tried to replace the internal hard drive with a 1TB Crucial MX500 SSD but the iMac doesn’t recognise it when it’s connected internally. It doesn’t come up in Disk Utility at all. iMac is an 18,2 Retina 4k
The original HDD still works when I connect it internally, so I know the cable isn’t broken. The new drive works fine in an external enclosure, so I know the drive is working.
I plugged in an SSD from a different Mac and it works fine internally. Just not this new one, I bought the drive specifically from a Mac upgrade kit, so I assumed it should be compatible?
Am I missing a setting for it? Firmware? Is there some kind of voltage incompatibility? I noticed the original drive is 5V 1.6A, the new SSD I have is 5V 1.7A. Could .1amp cause issues?
Any help is appreciated, I’m going to buy another new SSD with a smaller capacity and see if that works
2 Comments
What is your exact model? There are some issues you might be facing depending on the explicit model. Plug in your systems S/N inter here EveryMac - Lookup. To find your S/N flip over your system looking at the foot for a sticker which has it. Let us know what you have.
by Dan
@danj It's A1418 EMC3069 MNDY2LL/A
No fusion drive, it just had a 1TB HDD in it
by tharaka
