Not powering on. DC in board at fault?
Recently received this MBP which will not turn on using either battery, mains only or both.
Things I have tried:
- SMC reset (no change)
- Unplugged battery and used magsafe (no change)
- Shorted the power pads (no change)
- RAM taken out (no change)
When magsafe is connected it is a solid green bright light which never changes to orange. Pressing the BLI presents 5 flashes or green LEDs. Occasionally it flashes with only the first LED rapidly then goes back to the 5 flashes of LEDs.
Unplugging the battery and repeating this method, it is still flashes all LEDs 5 times. As the battery is disconnected I suspect it to be a problem with the DC in board. Took a closer look and to me it seems the board has had some sort of water damage? I was informed this unit had no water damage and none of the water indicators have been activated.
What do you think looking at the board? Am I on the right track to the fault?
