Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
Vertical bars on screen
I have the same issue on the last version of the 17inch mbp is it fixable on that version? Or same all broke needs chucking out?
2 Comments:
Please post some pics on what you are seeing Adding images to an existing question
by
There are known issues on some of these models. Please identify your exact machine so we can give you correct advice. Go here and enter your serial number then tell us what you have.
https://everymac.com/ultimate-mac-lookup...
by
Add a comment
Vertical lines seen on a computer screen may be a result of hardware failure, which requires a hard reset (or forced reset), or an issue with your video (graphics) card. In most cases, these lines are caused by damage to the screen lite blue
1 Comment:
@david236 - True! Its likely a hardware issue. But it can be the GPU instead of the the display. We also have a few cards up our sleeve to over come some issues! But I need to get a better idea what the OP is seeing as that will give me a clue on what's needed.
by
Add a comment
OK, I see the faint vertical lines which are equally spaced (more visible in the top right in you pic) This looks like a noise issue within the internal displays LVDS connections.
Let’s do one more test to make sure. Connect your system to an external monitor do you see the lines on it as well?
Add a comment
Add your answer
yeknommonkey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 245
