2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Replacement Battery Dropping Suddenly to 7%
I’ve just replaced my battery using the kit from iFixit. Everything seemed to go well according to coconutBattery , and I calibrated it per the instructions (full charge -> use it until it goes to sleep and wait -> full charge).
For some reason, when I start using it, the battery discharges normally for some time, then drops suddenly to 7%. It will stay usable on 7% for quite a while, then it dies.
30 minutes later:
This happened on the first cycle, and after I charged it fully (which was slow, took ~ 5hrs - not sure if that is part of the same problem), it has happened again.
It seems other folks have had similar problems with these replacement batteries - is there any way to fix this? Are there any reliable sources for these batteries? It is quite an involved process to try new batteries until finding one that works if so many being shipped are unreliable.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Sorry for the bad luck, contact the store to get a free replacement!
Score 3
2 Comments:
Shoot, I was afraid this was going to be the answer. Thanks for the info.
Do you happen to know if the adhesive on the replacement batteries is easier to remove, or will I need to go through the same process again?
by
The adhesive should be a bit easier to break the bond to the case using the same method as before.
by
Add a comment
Add your answer
mp_fix will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 6
All Time: 180
