Whirlpool washer error F25
Hi,
A 3-year old Whirlpool washing machine stopped working. At the very beginning of the cycle it turns the drum a tiny bit and stops with the Draining red light blinking. I read error code and got F25.
I did what was was recommended here for similar questions: took off the front, wiggled all connectors on the control panel and what I could reach by hand at the bottom. There is no corrosion, all clean and tight.
Under the drum, I found a plastic part that broke off, see pic attached. I can’t find where it belongs to. Can it cause the issue here?
Other suggestions?
Thank you
Update (10/08/2019)
Model WFC7500VW 2
TYPE: 826-02
MOD
Thank you
7 Comments
Boris Dainson what is your washers complete model number?
by oldturkey03
I looked at the parts tear down and could not spot the part. Maybe @ladytech has a clue.
https://www.repairclinic.com/ProductDeta...
by mayer
its for shipping it holds the drum in place it was removed when installed they just didn't catch that one.
by Jason Fulton
Did you get yours figured out? How did you fix the problem?
by KELLIE BLACKHURST
No, I had to buy a new one
by Boris Dainson
Show 2 more comments
