Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Questions View all
charging and home buttons not working after screen replacement
hi, so i’ve recently replaced the screen on my iPhone 8 Plus, and now i’m facing the following problems with it:
  • it’s only charging wirelessly, tho the Lightning port is giving audio signals to the headphones.
  • the home button is not working, but Touch ID does.
what do you suppose is the problem?
Update (10/08/2019)
also, it turns off by it seld when shaken or moved too much
Add a comment
Charger port might need replacement
The home button could be effected or if you have another screen to try it on to see if old screen isnt completely broken test it on the old
Add a comment
The loss of home button functionality while retaining the use of Touch ID is likely caused by damage to the IC that is on the home button. To resolve this you could either bring it to Apple for a screen replacement (where they’ll replace the home button with the whole display) for $219.00CAD or you can order a replacement home button from JC or HX and you’ll regain the home button, but lose Touch ID functionality.
As far as the charge port issue, it could be some damage to the flex cables that is preventing charging but allowing audio, you’d have to connect a working chargeport to the phone and see if there’s any change.
Hope this helps!
Add a comment
Add your answer
Bibars Bara will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 7
All Time: 567
