Repair guides for smartphones manufactured by LG that use the Android operating system (OS).
2552 Questions View all
LG G6 black screen
Hello I fix people:)
I got a black screen with the battery icon and a red question mark flashing non-stop….. I opened it to check if everything was well connected…and yep..all good…do you have any idea wtf is wrong with it? (LG G6)
1 Comment
Thanks @refurbpro ...a new battery is on it’s way
by
Add a comment
Chosen Solution
To the best of my knowledge, the LG G6 supports wireless charging, most wireless chargers also contain the battery temperature sensor. The battery won’t charge, and most likely wont turn on if the phone can’t read the battery temperature. I would make sure you havent damaged that component when you replaced the screen.
Score 2
2 Comments:
what would said component look like?
by
https://www.ebay.com/itm/Wireless-Chargi...
Sorry for the late reply, but up above, I linked a replacement part for the Wireless charging coil, if you think you have somehow damaged it, you might wanna look at replacing it. The part is less than 9 bucks, so not that big of a deal. I would look online to see if anyone else is having the same problem.
by
Add a comment
Hi @sophieifixqc
The question mark leads me to believe you may have a battery issue. I would try a replacement battery to fix this issue.
It is a good idea to check for any type of water exposure while the device is opened. This will present as a blueish turquoise colored corrosion on areas of the logic board. If you don’t find anything like that, you’re good!
LG G6 Battery Image
Product
LG G6 Battery
$24.99
Score 2
Add a comment
Add your answer
Sophie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,625
