General repair information on LG washing machines.
LG WM2233HD doesn't spin or agitate
LG front load washer doesn’t agitate or spin.
It fills water, drains water. But no agitation and no spinning
It jerks when attempting the rinse agitation.
And jerks again at the start of the spin cycle. Not even an inch of spinning.
Appears as if something is stopping it from spinning.
Thank you.
Score 2
Add a comment
1 Answer
Chosen Solution
Solution 1:
Stator Assembly
The stator interacts with the rotor to create a strong electromagnetic field which rotates the tub in either direction. If the windings on the stator are damaged, the washer will not spin or agitate. Check the stator for damaged windings or other defects.
Solution 2:
Rotor Assembly
The rotor interacts with the stator to create a strong electromagnetic field, which rotates the tub in either direction. If the magnets on the rotor are damaged, or any part of the rotor is defective, the washer may not spin or agitate. To determine if the rotor is defective, inspect the rotor for damage. If the rotor is damaged, replace it.
Solution 3:
Tub Bearing
The tub bearing is mounted in the middle of the outer tub of the washing machine. The tub bearing helps to keep the inner tub spinning smoothly. If the tub bearing is defective, it can lock up and prevent the washer from spinning. The washer may also make a loud rumbling noise. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly.
Solution 4:
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy and the tub can stop spinning. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
Solution 5:
Door Lock
Inspect the door strike assembly for damage. If the door strike is broken, replace it. The door strike is not repairable—if it is broken, you must replace it.
https://www.repairclinic.com/RepairHelp/...
Score 2
2 Comments:
Thank you Mr. Mayer. I really appreciate your quick response within hours.
I took the rotor assembly out. I noticed that the bolt assembly was not as hard while unscrewing.
The plastic gear wheal was all ground out/worn out. The plastic strips were all held inside.
The stator and the rotor magnets seem to be fine. Does it need a new rotor?
Thank you
GR
by
@grnrrr It would really help if you posted a photo. Here's how you can do that:
Adding images to an existing question
by
Add a comment
Add your answer
Gurusamy Rajendran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 1,796
