iPhone freeze then turns black. SEND HELP!
My iphone frequently freeze then turns black.
Software problems can cause an iPhone to shutdown randomly. Try closing other apps and close any open tabs you might have open in safari/other browsers.
If your iPhone’s storage is almost full, try deleting some info/apps off the device until you free up at least 10% of the total device storage.
It is a good idea as well to back-up and reset the device software to rule out any additional software problems.
First check out phone detect on dfu mode or not via iTunes.If PC detect the phone restore it .If not try to force DFU mode.Finally if all fails that must be hardware issues.
Has your phone had water dmg in the past?
Most likely a battery replacement
Try a hard rest you hold the power button and home button
@consistent already did that several times. :( also, my battery just got replaced.
@kayanneyu2157 are you able to connect it to itunes?
@consistent I was able to connect it to itunes when it was turned on but when it freeze and turned black it doesn't connect to itunes :(
The phone could be shorting out screen replacement only have the Screen and battery connected and if that doesnt work its a logic board repair
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
