Samsung smartphone released in January 2016. Model SM-J320
48 Questions View all
Why wont my screen work?(Black Screen of Death)
Hi, so on my J3 2016, I went to turn it on one day but it didn’t. I just assumed it was dead, so I plugged it in. When I plugged it in the phone vibrated, so I thought it was charging and left it there. Fast forward 3 hours later, I come and check on it, and it doesn’t power on. How can I fix this?
Thanks in advance!
Add a comment
Chosen Solution
What causes you to believe this is the black screen of death? What steps have you taken to narrow this down? Your description doesn’t rule out a simple power, battery, or charging issue.
2 Comments:
I tried multiple chargers, took the battery out and plugged it in to see if it would turn on. Also, when I plug it in, it vibrates but nothing shows up.
by
Gotcha. You are right that it's taking a charge. I don't want to jump the gun, but out of curiosity, have you tried a hard reset using the hardware buttons?
by
Add a comment
Most Helpful Answer
Hi @random_user_101
Generally if the phone works properly with nothing on the screen, it is a screen related issue. You can check the screen connection easily from the connector on the backside of the phone.
If you are still having screen problems, you may need a replacement screen assembly.
Score 1
Add a comment
Add your answer
Random _User_101 will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 18
All Time: 652
