The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
Certain buttons not working
The decimal, 2, 5, 8, (, and the cos button are not working on the calculator. I let my brother borrow it and when i got it back it worked fine. I havent used it in a few weeks. Ive done everything the other forums say to do, and it still isnt fixing it. I reset the whole thing, reset with the button on the back, etc etc. Please help i have my act tomorrow and need a calculator for my math class.
Score 1
Add a comment
1 Answer
Chosen Solution
This sounds a lot like a hardware problem with a circuit that’s broken for that key column. Unfortunately, I don’t know how to help you fix the issue from the hardware side and from the information I gathered I don’t think you’ll be able to fix any hardware issues before your ACT. However, MateoConLechuga may have away to fix it through software
  • Press [prgm] (If that button doesn’t work leave a reply and I’ll describe how to do it another way)
  • Scroll to the right over to ‘NEW’ and press [enter]
  • Type in the letter A and press [enter] again
  • Press [2nd]>[0] and scroll down to Asm84CEPrgm (If this is crossed out in blue, leave a reply and I’ll describe how to do it another way)
  • Press [enter]
  • Now type in EXACTLY the following characters (they should be on the same line as the Asm84CEPrgm token)
  • 210100F53678C9
  • Press [2nd]>[mode]
  • Press [2nd]>[0] and scroll down to Asm( and press [enter]
  • Press [prgm]
  • Press [enter] on program A
  • Your screen should look like Asm(prgmA
  • Press [enter]
  • If it just says ‘Done’ then it should have worked. Try the buttons again and let me know if they work again!
Since your calculator may not be reliable, I think your best bet is to see if your ACT proctor has a spare calculator or if some student brought along a spare. If there’s no spares, then just know that most commands and operations you need are available in the catalogue (which you access by pressing [2nd]>[0]).
Score 2
2 Comments:
Hello, Asm84CEPrgm is crossed in bleu. Can you help me ?
by
@albertsiebe you got suckered by TI. There's more info about it and a possible fix here: https://www.youtube.com/watch?v=dGq-nsNO...
by
Add a comment
Add your answer
Aspen Simerly will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 49
All Time: 3,364
