Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
iPhone 4 Back Panel will not fit...
I just changed my digitilizer and my phone works but the back panel will not fit back on. I know how to put it one but it just won't fit... Please help and Thank You everyone!
Score 1
1 Comment:
Did you solve this because I am having same problem
by
Add a comment
Redo the repair and check that nothing is out of place. Are you sure you have an iPhone 4? On the iPhone 4 the LCD+Digitizer+glass is one unit, and is replaced as such. Also, the rear panel is a simple matter of unscrewing two screws at the bottom and rescrewing them.
1 Comment:
Yes, it was the iPhone 4. When I put the back panell on the phone so you can slide it down it wont slide down. Thank you for your advice!
by
Add a comment
After repairing my power switch on my iphone 4 I couldn't get the back panel to fit back on. Everything else was working properly, except the logic board was getting in the way of one of the clips on the back panel, and after repeated attempt to reposition the logic board the screws were beginning to get stripped, so I just removed (cut off) the one clip, and it fit back on perfectly.
Add a comment
which clip did you cut
1 Comment:
507341 1059 with reply thx
by
Add a comment
Mine wont fit cause one side will go down and the other one wont. It like the battery is in the way of it.
Add a comment
put on a hard surface put back cover on and hit repeatedly with large hammer pick up wot remains and put in rubbish bin AND BUY NEW PHONE[a latter version]
Add a comment
Add your answer
samstertheclown will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 6,241
