In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
MacBook air replace screen
My mac book screen is broken so i buied mac book display assembly.The repair is almost over and i tried to put the connector, but the connector does not put in. How can i repair this mac?
https://youtu.be/kyrljFnByPY YouTube from 4 minutes 10 seconds
1 Comment
This is attached to the MacBook body I had
by
Add a comment
1 Answer
Most Helpful Answer
It looks like you got the wrong display assembly!
Here’s the correct one MacBook Air 13" (Mid 2013-2017) Display Assembly.
In your pictures you can see the long cable LVDS you have (held by the tweezers) needs to be much shorter and also uses a slightly different connector than the correct displays LVDS cable.
You’ll need to take it off and return it to seller.
Replace a display compatible with the model A1466 Mid 2013 to 2017 MacBook Air 13" laptop. Includes the 1440 x 900 LCD 13.3" screen, aluminum case and camera. Part #661-7475, 661-02397, 661-02505. Image
Product
$299.99
Score 1
2 Comments:
by
Let's back up here You are swapping displays between two systems which are not the same model and year?
Look at it this way... A truck tire won't fit a car's rim so why would you expect a MacBook display would fix a MacBook Air? Very different part.
by
Add a comment
Add your answer
ilwootwo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 185
