MacBook Air (13-inch, Mid 2013), board issue. help please
Hi there,
I have a friend who had the “Service Battery” warning come up for him a few months ago, and instead of taking it in to be serviced, he waited until the device fully shut down before looking into the issue. the battery replacement doesn’t work. The fuse on the F7140 is testing at 8.6V on both sides, so it is still intact. does anyone have a good guide on how to troubleshoot this problem?
I have the schematic, the board diagram, and the soldering skills to do this repair. if anyone could help, I would appreciate it.
Thankyou
4 Comments
@phonesandbones with the MBA on what voltages do you get on the left and right outer contacts of the battery connector?
by oldturkey03
@oldturkey03 the voltage is reading at 7.85V
by Scott Reidel
@phonesandbones you should get about the same on the battery connector than what you get on the fuse. . Since you have the schematic etc. I would check PP3V42_G3H PPVBAT_G3H_CHGR_R and PP5V1_CHGR_VDD Let's see if that shows proper voltages
by oldturkey03
@oldturkey03
PP3V42_G3H; 3.44V
PPVBAT_G3H_CHGR_R; 8.41V
PP5V1_CHGR_VDD; 5.05V
everything appears to be in tolerance.
by Scott Reidel
