Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Questions View all
Is there a trick to replacing the battery cover screws?
Everytime I attempt to put the screw back into the battery cover,the screw seems to change polarity flip upside down or jump out and stick to the side of the case..
Is there a good tip /technique to doing this I wonder?
I’ve got this far after first time battery and display renewal,so this is infuriating to say the least !!
Add a comment
1 Answer
Most Helpful Answer
Magnetize a Screwdriver
the screws will then go to the screwdriver
One way and may explain the theory
https://www.wikihow.com/Magnetize-a-Scre...
Score 2
1 Comment:
Thanks Bill
I was thinking that was why it was happening it seemed the screwdriver was changing the polarity hence the flipping over of the screw as soon as the magnetized driver and screw got near the hole -like it was being repelled like magnets do when you try and push them together if you known what I mean..
Never had that happen before so what was going on there I'm not sure...It shouldn't be spitting the screw out should it!
In the end I used an actual magnetic bar of the same diameter as the screw head and was able to start it off in the hole so it wouldn't be able to jump out and then screw it fully down with the driver...lucky to find that magnet , and now I'll keep it safe in my tools.
Thanks for the link I'll check that out
by
Add a comment
Add your answer
EAMONN COLLEY will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 98
