My Right side USB port is not working.
The right side usb port on my macbook pro isn’t working , not even a thumb drive is recognised , the left one though works fine.
please help what can be the reason and possible parts that can be faulty.
2 Comments
Good idea to check for debris in the socket and clean the contacts with applicable contact cleaner or 90% or higher concentration isopropyl alcohol. If you open up the unit, check the USB connector for cold/cracked solder joints, loose terminals between the circuit board and the connector (if possible) and any looseness of the connector itself.
by prop man
@propman Thank you for the fix , I did have to replace the io board.
by Jil Patel
