The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Questions View all
Why does my MacBook air power off when battery under 10%
Device MacBook Air (13-inch, Early 2014)
System 10.14.6 (18G87)
A year ago, MacBook Air began to report in the battery bar that the original battery need to repair. The final situation was that the computer was powered off when the battery was low (less than 20%) and the screen cannot been light up. Looks like when the voltage is insufficient, the motherboard will be powered off. Then click the power button again the sign (the red battery warning logo after low battery shutdown) will not show up.
After replacing the third-party battery and resetting the SMC, the battery life has improved, but the low-power instantaneous shutdown threshold has also been reduced to less than 10%, but it has not been resolved. So that I have not seen the notice of less than 5% of battery for several months.
Is this a problem with the power management chip?
Update (09/01/2019)
Most time when I press the power button after MacBook has shutdown automatically, it will restart and shutdown again while the white apple progress bar half.
1 Comment:
Lets get a snapshot of CoconutBattery so we can see what your battery and charging looks like. Take one with the MagSafe connected and a second running on battery. Post them both here so we can see Adding images to an existing question
by
Add a comment
1 Answer
At this point your battery looks OK, its reacting as I would expect. Given the fact you have replaced the battery a few times I’m thinking you have a logic board issue within the power rails. Did the system get wet or have a liquid spill?
You’ll need to find someone with deeper skills and access to the schematics to figure out what rail is failing. The other option is just replace the logic board.
Add a comment
Add your answer
der will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 83
